BIM 360 API Forum
Welcome to Autodesk’s BIM 360 API Forums. Share your knowledge, ask questions, and explore popular BIM 360 API topics.
Why I get complained about "Max retries exceeded with url: /api/get_issues"
5 REPLIES 5
46963 Views, 5 Replies
We have one very frequent error when my python program called your API-endpoints (get_issues  & get_equipment)  :
    Exception Error when running API to grab Issue JSON data !
    Error (REQUEST): HTTPSConnectionPool(host='bim360field.autodesk.com', port=443):
    Max retries exceeded with url: /api/get_issues (Caused by ProxyError('Cannot connect to proxy.', error("(104, 'ECONNRESET')",)))
    Exception Error when running API to grab Equipment JSON data !
    Max retries exceeded with url: /api/get_equipment (Caused by ProxyError('Cannot connect to proxy.', error("(104, 'ECONNRESET')",)))
I wonder if there is a limit to make those API-calls daily. Otherwise, I will not receive the message ‘Max retries exceeded’
If so, what is the limit number for one day?
And such error always happen when I used such API end-points with the expectation of
large number of records returned
Please advice! thanks much !!!
Ryan
Ryan
5 REPLIES 5
Takes really really long time to get a 'legitimate' answer here.
I submitted one question 2 weeks ago, no response!  Not even a follow-up question for clarification of what I mean !
frustrated
frustrated
mikako_harada
mikako_harada
Hi Ryan,
There is no mechanism built into the Field (classic) API to limit API calls.  I checked with the product team to confirm.
I don't know Python.  But I googled with keywords in the error message.  I saw some reporting similar error messages.
You may want to try stackoverflow for programming question.  e.g.,
https://stackoverflow.com/questions/43165341/python3-requests-connectionerror-connection-aborted-ose...
Mikako Harada
Developer Technical Services
Hi Ryan,
Mikako Harada
in reply to: mikako_harada
'ECONNRESET' is the consequence (=> get the connection terminated)
but 'Max retries' is the reason.... I got from your API endpoints. I think it's proprietary.
and you have no clue for that?  that's not convincing. Can you elaborate more?  thanks much !!
I found the reason, it is because of the limit of inflow data-size in our proxy.
Instead of one single API call for returning all EQUIPMENT's attachment data of one project,
i need to break it down as a loop with parameters offset & limit set as 30.
The reason 'Max retries exceeded' is definitely misleading.
can you provide the code?
