I'm having trouble with the quality of the MEP and some ceiling plans. When I zoom in they look like pictures with very low quality.
Should I change something on the view range or what might it be?
Hi
Looks like you are using BIM 360 Docs and the viewer inside. I don't believe there is any additional control there. I cannot tell what exactly the issue is in your image. You may want to report to BIM 360 Docs product forum as this forum is about API.
https://forums.autodesk.com/t5/bim-360-docs-forum/bd-p/183
Currently, there is not API to customize the viewer used in the Docs directly.
That said, I'm aware that occasionally, I hear our partners reporting a poor quality of rendering, such as rebar of Revit model using Forge viewer.
If this is about using Forge Viewer, we may want to have an example of a model that we can report to the product team.
Hi
