Issues API return project not found
tan.nv
tan.nv
Hi everyone,
Following up on this tutorial: Retrieve Issues (new) | BIM 360 API | Autodesk Platform Services, I don't know why the response error code is ""ISSUES_SERVICE_NOT_FOUND"". I already enabled the BIM 360 API in my client credentials as picture below.
Not sure which is the problem here. Appreciate any support here.
Thank you.
tan.nv
I changed from BIM360 API to ACC API and everything is working as expected.
Thanks.
noyolbolot
Community Visitor
Community Visitor
Unauthorized will indicate to the browser the request would have succeeded with proper authentication, so the browser will try to get credentials and retry the request. And this attempt may very well shove a login prompt in front of the user (for HTTP Basic Authentication)*. Unless this is what you want to happen, don't return an HTTP 401 https://speedtest.vet/ https://vidmate.bid/  .
