Is there any way to extract Job Number of a project using the BIM 360 Field REST API? We tried using "api/projects" call, but the Job Number was missing in the JSON result.
You need to get the specific Project Id from the list of projects, then make a call to the /api/project method and pass the Project Id value along with a ticket to get the information specific to that project. In this return you will get a value for "identifier" which is the project number.
Keith
Following CURL example will output required job_number
curl -v 'https://developer.api.autodesk.com/hq/v1/accounts/e3d5ef8d-5c37-4b9d-925d-1e6d24753ace/projects?limit=1&offset=0&sort=name' \ -H 'Authorization: Bearer 9ezBnx9Rd5D1xG4KMt6b72T4w0MG'
Example RESPONSE
[ { "id": "aca11a7a-bd17-47cd-ab99-6548d0e6fe25", "account_id": "e3d5ef8d-5c37-4b9d-925d-1e6d24753ace", "name": "construction_project", "start_date": "2015-05-02", "end_date": "2016-04-03", "project_type": "office", "value": 3000.0, "currency": "USD", "status": "pending", "job_number": "0219-01", "address_line_1": "The Fifth Avenue", "address_line_2": "#301", "city": "New York", "state_or_province": "New York", "postal_code": "10011", "country": "United States", "business_unit_id": "c17e6837-96cd-4839-868e-051a2ad65d28", "timezone": "America/New_York", "language": "en", "construction_type": "Renovation", "contract_type": "Design-Bid", "last_sign_in": null, "created_at": "2016-04-05T07:26:20.858Z", "updated_at": "2016-04-05T07:31:26.290Z" } ]
Details in this link GET projects | BIM 360 API | Autodesk Forge
