BIM 360 API Forum
Welcome to Autodesk’s BIM 360 API Forums. Share your knowledge, ask questions, and explore popular BIM 360 API topics.
How do I grant multiple users access to multiple services at the same time?
0 REPLIES 0
Message 1 of 1
howislands
197 Views, 0 Replies
howislands
I'm having issues adding users to BIM 360 services in a new project using the API.
I want to add an admin and a group of standard users to each service in a new project (Docs, Field Man, etc.).
What we want to accomplish with the API is as follows:
Do a new project (This is working fine)
Activate services such as Doc. Man., Field Man., etc., as well as add an Administrator (This is working fine)
Add the following regular project members to these services: This does not appear to be working as expected. Even though this is possible for the Document Management service
We do not see how we can add standard users to other services such as Fieldman.
So our main issue is that we don't see any way to add a bunch of standard users to Doc. man. and Fieldman. All at once.
What steps must we take?
We've already tried the following, but without the desired results:
Use the first call to activate the service with one admin, and then use the second call to add standard users to the service.
This works fine, but the call to add standard users is only available for the Document Management service.
There appear to be no calls available to add standard users to other services such as Field Management.
Are there any solutions?
Tags (1)
0 REPLIES 0
