Discrepancy in methods to post relationships
- Mute
- Permalink
- Report
With the endpoint https://forge.autodesk.com/en/docs/data/v2/reference/http/projects-project_id-versions-POST/ one can assign versions and add relationships to items with the body
data: dict = {
"jsonapi": {"version": "1.0"},
"data": {
"type": "versions",
"attributes": {
"name": fileLocationAsPath.name,
"extension": {"type": autodeskVersionType, "version": "1.0"},
"relationships": {
"item": {"data": {"type": "items", "id": itemId}},
"storage": {"data": {"type": "objects", "id": objectId}},
"refs": {"data": childReferences},
Where childReferences is a list made with (a) childReference object(s):
"type": "versions",
"id": childVersionId,
"meta": {
"refType": "xrefs",
"direction": "from",
"extension": {
"type": "xrefs:autodesk.core:Xref",
"version": "1.1",
"data": {"nestedType": "overlay"},
This works fine, for both first and all subsequent versions. However, due to the limit of 200 child items (see this forum post) I'd like to use the https://forge.autodesk.com/en/docs/data/v2/reference/http/projects-project_id-versions-version_id-re... endpoint to do so. However, using the body (for a test with two child versions)
{'type': 'versions',
'id': childVersionId,
'meta': {'refType': 'xrefs',
'direction': 'from',
'extension': {'type': 'xrefs:autodesk.core:Xref',
'version': '1.1',
'data': {'nestedType': 'overlay'}}}}I get the response:
{'jsonapi': {'version': '1.0'},
'errors': [{'id': '7433722e-029e-48a8-b6b2-a97baa715718',
'status': '400',
'code': 'FUNCTION_NOT_SUPPORTED',
'detail': 'BIM360 currently does not support the creation of refs.'}]}And with the body
'data': [{'type': 'versions',
'id': childVersionId0,
'version': '1.1',
'data': {'nestedType': 'overlay'}}}},
'id': childVersionId1,
'version': '1.1',
'data': {'nestedType': 'overlay'}}}}]}The following is returned:
'errors': [{'id': 'd3679c47-4341-401e-9a69-9d0fef2e3bf1',
'status': '400',
'code': 'BAD_INPUT',
'title': 'One or more input values in the request were bad',
'detail': '"data" at line 1, pos 41 is empty or contains more than one child.'}]}
So the question is, how can one add 200+ child references to an item? The endpoints above seem both unsuitable.
