BIM 360 API Forum
Welcome to Autodesk’s BIM 360 API Forums. Share your knowledge, ask questions, and explore popular BIM 360 API topics.
Converting from Forge externalId into IfcGuid [model-derivative-api]
0 REPLIES 0
Message 1 of 1
peter.kolbe
575 Views, 0 Replies
peter.kolbe
References:
https://thebuildingcoder.typepad.com/blog/2009/02/uniqueid-dwf-and-ifc-guid.html
https://github.com/Autodesk-Forge/bim360appstore-model.derivative-nodejs-xls.exporter
https://gist.github.com/jsdbroughton/8ead390ad03f9e26658a80f461276472
Following the sample “bim360appstore-model.derivative-nodejs-xls.exporter” I’m able to export the metadata from a BIM360 model. Each forgeObject has a property “externalId” in format 8-4-4-4-12-8. I need to convert this into the IfcGuid (22 characters long).
When using Revit C# API I have to call
            Guid elemGuid = ExportUtils.GetExportId(element.Document, element.Id);
            String ifcGuid = IfcGuid.ToIfcGuid(elemGuid);
to get the ifcGuid. How can I do the same using JavaScript in Forge environment?
I tried it, using the JS code from J. Broughton from the references above, but the input data for function fromFullToCompressed() is a 8-4-4-4-12 value, and not the 8-4-4-4-12-8 externalId.
So how to do the first step converting from externalId to elemGuid?
References:
0 REPLIES 0
