BIM 360 API Forum
Welcome to Autodesk’s BIM 360 API Forums. Share your knowledge, ask questions, and explore popular BIM 360 API topics.
Connecting to the api with the correct scopes. Help!
1 REPLY 1
600 Views, 1 Reply
I am using php to create a little snippet of code to create a bucket on my new app. This is a simple question but how o I add multiple scopes to my request. Here is my code.
$headers[] = 'Content-type: application/x-www-form-urlencoded';
$process = curl_init();
curl_setopt($process, CURLOPT_HTTPHEADER, $headers);
curl_setopt($process, CURLOPT_URL, "https://developer.api.autodesk.com/authentication/v1/gettoken");
curl_setopt($process, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($process, CURLOPT_POSTFIELDS, "client_id=myclientid&client_secret=myclientsecret&grant_type=authorization_code&code=" . strval($code) . "&redirect_uri=http://localhost/siteForge/home.php&scope=code:all");
curl_setopt($process, CURLOPT_POST, 1);
$result = curl_exec($process);
curl_close($process);
Also when I try to make the bucket I says I do not have the privileges.
Tags (3)
1 REPLY 1
mikako_harada
I'm not php person.  But using a tool like postman, where it shows three variation of php codes like below as an example.
You may want to make use of a tool like that.  you probably have better chance to get help by posting to stackoverflow as this is more about programming language questions.
e.g.,
curl_setopt_array($curl, array(
CURLOPT_URL => "https://developer.api.autodesk.com/authentication/v1/authenticate",
CURLOPT_RETURNTRANSFER => true,
CURLOPT_ENCODING => "",
CURLOPT_MAXREDIRS => 10,
CURLOPT_TIMEOUT => 30,
CURLOPT_HTTP_VERSION => CURL_HTTP_VERSION_1_1,
CURLOPT_CUSTOMREQUEST => "POST",
CURLOPT_POSTFIELDS => "client_id=<>&client_secret=<>&grant_type=client_credentials&scope=data%3Aread%20data%3Acreate%20data%3Awrite%20account%3Awrite%20bucket%3Aread",
CURLOPT_HTTPHEADER => array(
"cache-control: no-cache",
"content-type: application/x-www-form-urlencoded",
"postman-token: <>"
Mikako Harada
Developer Technical Services
Technology Administrators
