BIM 360 API Forum
Welcome to Autodesk’s BIM 360 API Forums. Share your knowledge, ask questions, and explore popular BIM 360 API topics.
Change status of issue from void to open via Forge API
0 REPLIES 0
Message 1 of 1
213 Views, 0 Replies
Is it possible to change the status of a created issue from void to open through Forge API?
I have read some older posts where it was declared that is not possible https://forums.autodesk.com/t5/bim-360-support/changing-issue-status-from-void-to-open/m-p/8574068/h...
But, this article is two years old and I have tried it and I am able to change the status form void to open as an admin in your web portal https://docs.b360.autodesk.com/.
So why is it not possible to do it via Forge API? https://forge.autodesk.com/en/docs/bim360/v1/reference/http/field-issues-:id-PATCH/ if I am logged as admin?
I receiving this error as response in request:
403ForbiddenThe user or service represented by the bearer token does not have permission to perform this operation.
0 REPLIES 0
