Hello all,
I am looking for some help connecting BIM360 API to PowerBI web services. I am able to connect and refresh successfully in the PowerBI Desktop app. However, when I publish to the web and try to refresh I am unsuccessful. It has to do with the base url used in the BIM360 API. PowerBI requires the base url to return a 201 success code. The BIM360 API base url does not. Has any one had any experience with this and figure out a way around this?
If not how could I submit a request for Autodesk to make some sort of adjustment to their API?
Here is an example of my code and the support answer for Microsoft...
Example of the code I am using in PowerBI:
let
Source = Json.Document(Web.Contents("https://developer.api.autodesk.com/",
[RelativePath= "project/v1/hubs", Headers=[Authorization="Bearer " &AuthToken&""]])),
data = Source[data],
in
Source
Microsoft answer:
if the root URL of the your api works with anonymous access, you can publish the report that uses the Headers option to pass an API key and the refresh should work in Power BI Service. However, if your root URL returns error with anonymous access, refresh in Power BI Service will fail.
Thanks for any help!
A 201 Status indicates that as a result of HTTP POST
request, one or more new resources have been successfully created on server. The BIM 360 API 200 indicates that the request has been processed successfully on server. Based on the code you provided it seems you are doing an API call to retrieve the Hubs available within BIM 360.
I don't think the need to modify the API response exists here. If what you need is a 201 status, you can maybe tweak the value that the BIM response gives you and if it is a 200 to pass a 201 to Power BI. We have many customers who have done integrations with Power Bi successfully which did not required a change on the BIM API. I personally I'm not familiar with Power Bi but I do know the BIM 360 side, and getting a 200 it is the correct status code it should be returning.
Cheers,
I should of been more specific. I can connect and refresh just fine in the PowerBI desktop. The issue is when trying to fresh with a scheduled refresh in the PowerBI web service. Microsoft PowerBI web service has to validate a connection the the base URL in the code. In this case it is "https://developer.api.autodesk.com/" This page returns a 404 status. It need to return a valid status code (200 or 201). Please see attached screen shot and error details at the bottom of post.
For example if you call something from the Field API. The base URL is "https://bim360field.autodesk.com/" which in PowerbI returns a success and allows you to refresh from the web service.
Here is an article on the issue with M query and API's.
Unable to connect: We encountered an error while trying to connect to . Details: "We could not register this data source for any gateway instances within this cluster. Please find more details below about specific errors for each gateway instance."Hide details
Activity ID: | bf07675d-4f8d-4929-a21d-d3201546d174 |
Request ID: | 63162f35-cd57-4bd9-3183-0016b190675b |
Cluster URI: | https://wabi-us-north-central-redirect.analysis.windows.net |
Status code: | 400 |
Error Code: | DMTS_PublishDatasourceToClusterErrorCode |
Time: | Fri May 03 2019 13:09:06 GMT-0500 (Central Daylight Time) |
Version: | 13.0.9264.166 |
PowerBI: | Unable to connect to the data source undefined. |
Underlying error code: | -2147467259 |
Underlying error message: | Web.Contents failed to get contents from 'https://developer.api.autodesk.com/' (404): Not Found |
DM_ErrorDetailNameCode_UnderlyingHResult: | -2147467259 |
Microsoft.Data.Mashup.ValueError.DataSourceKind: | Web |
Microsoft.Data.Mashup.ValueError.DataSourcePath: | https://developer.api.autodesk.com/ |
Microsoft.Data.Mashup.ValueError.Reason: | DataSource.Error |
Microsoft.Data.Mashup.ValueError.Url: | https://developer.api.autodesk.com/ |
