Hi, I'm trying to use Workato to connect to the BIM360 API, I've entered my credentials and established a proper oauth "connection".
However whenever i try to enter my hub ID i keep getting a "403 forbidden" error code.
My settings are Admin for the account, and i'm set as a member Admin on many projects, why am i getting a 403 forbidden error?
Is there any special setting i have to setup to begin using the API?
I've properly added the "b." prefix to my Hub ID.
Not sure if this was ever resolved but the documentation states you need to remove the "b." prefix to convert it from Hub ID to Account ID.
