After sharing a new package of Landscape model, everything turned grey in our coordination model (which has Architecture, Landscape, structure,... models linked in)
when I view models separately in BIM 360, they seem to be ok, except the Landscape which has the same problem.
I am posting two screenshots, before and after the "Grey out" !
PS: neither I nor the landscape architect have an idea where the red color comes from either.
appreciate any ideas
Solved by PAAIMJHCN. Go to Solution.
Hi there, did you get this issue resolved? I'm having the same problem.
Hi
the issue was solved by Autodesk development team. try to publish your model again, hopefully it will look fine.
Hi
