BIM 360 API Forum
Welcome to Autodesk’s BIM 360 API Forums. Share your knowledge, ask questions, and explore popular BIM 360 API topics.
API Document_reference usage
2 REPLIES 2
827 Views, 2 Replies
Hi
I am trying to link already uploaded documents in BIM 360 to Equipments within a model. I believe document_reference can be used to achieve the same, reading through the documentation, I understand that it needs document reference unique ID and document_id (GUID) as part of the document reference hash which is passed as parameter to the API.
My question is how to get this detail from BIM 360, is there an API which lists existing documents with its internal details like unique ID and GUID etc. ?
Please help.
Sandeep
Hi
Please help.
Sandeep
2 REPLIES 2
mikako_harada
mikako_harada
Hi Sandeep,
could you try like:
POST /api/document_references
ticket=xxxx&
project_id=d80067a3-97ce-1f34-a4be-02cc3afa57bd&
document_reference=
"id":"d629b2fe-ab4b-11e3-2828-027465b920a7",
"document_id":"db102d99-97ce-11e2-a4be-02cc3afa57bd",
"container_id":"256D2E06-C8B2-4185-12a4-8BD38E349E15",
"container_type":"Equipment"
(linebreaks are added for readability.)
where
id - unique ID. if you are using .NET, you can use Guid.NewGuid to tgenerate new one.
document_id - id of a document.  you can use api/library/all_files.
container_id - id of equipment. you can use api/get_equipment.
Mikako Harada
Developer Technical Services
Hi Sandeep,
could you try like:
ticket=xxxx&
document_reference=
where
Mikako Harada
in reply to: mikako_harada
Thanks Mikako, I have now finally got the API to work, we are now able to link Equipments with Documents.
Thanks for all your help.
Sandeep
Sandeep
