ACC Connect Bluebeam and Candy connections
james.philip
james.philip
Does ACC Connect have recipes or could be configured to work with Bluebeam or Candy data packages?
mikako_harada
Hi James,
Does not look like they are supported.
ACC Connect uses workato platform. You can check what other applications are supported by searching the application name on this page:
https://www.workato.com/integrations
Both bluebeam and candy didn't hit any.
Also please note that this forum is about API, application Programming Interface. It is intended for discussion for coders/programmers.
For product side questions, please use this one:
https://forums.autodesk.com/t5/bim-360-support/bd-p/183
(I'm not sure if ACC Connect support is a part of this. But at least it will be a good starting point to find out if there is a designated one.)
Mikako Harada
Developer Technical Services
