3 legged auth - cannot create folder forbidden
kevin.bza
kevin.bza
Greetings,
Scopes: data:read data:write data:create data:search bucket:create bucket:read code:all bucket:update
with 3 legged auth. Result is forbidden. Code below - what did I miss?
I am trying to use httpclient instead of the nuget packages. Dev with nuget packages is working correctly, can create folders that way, but I need to use httpclient.
Thx for reading,
K.
        var url = $"https://developer.api.autodesk.com/data/v1/projects/{projectID}/folders";
        var folderData = new
            jsonapi = new { version = "1.0" },
            data = new
                type = "folders",
                attributes = new
                    name = "AgainNewFolderAgain",
                    extension = new
                        type = "folders:autodesk.core:Folder",
                        version = "1.0"
                relationships = new
                    parent = new
                        data = new
                            type = "folders",
                            id = folderId
        var client = new HttpClient();
        client.DefaultRequestHeaders.Clear();
        client.DefaultRequestHeaders.Add("Authorization", "Bearer " + accessToken);
        var response = await client.PostAsJsonAsync(url, folderData);
        if (response.IsSuccessStatusCode)
            Console.WriteLine($"Folder created successfully.");
        else
            Console.WriteLine($"Failed to create folder. Status code: {response.StatusCode}");
kevin.bza
folder type! Even though this is an ACC platform Project - the folder type in JSON is: folders:autodesk.bim360:Folder
