Hi!
I am noob at Bifrost Graph, and I have been studying for 3 weeks.
I tried to convert this Blender Geometry Nodes tutorial ( https://youtu.be/R3C34FkF9nw ) to Bifrost Graph, but I have a error when I put the Pi node.
The Chladni Plate’s formula ist: cos(n pi x / L) cos(m pi y / L) - cos(m pi x / L) cos(n pi y / L) = 0
http://paulbourke.net/geometry/chladni
The rings of power opening: https://youtu.be/pNMtW76IPxQ
Could you help me?
Solved by sepu6. Go to Solution.
Plane
Width / Lenght: 10
Width/ Lenght Segments: 30
You can watch in Tutorial at 2'02": https://youtu.be/R3C34FkF9nw?t=122
Worked on my side. I just added a round node to pi... but not really necessary.
ok, so a field in blnder probably is not the same as BF fields. so instead use a get point position from the plane and then do the vector to scalar and that will work.
