Rebel Pack 0.4.0 for Bifrost 2.2 Released!
We have a new rebel pack for you! This version of the Rebel Pack, 0.4.0, works with Bifrost 2.2 and later versions.
https://area.autodesk.com/downloads/rebel-pack-040/
How to install compounds and graphs: https://help.autodesk.com/view/BIFROST/ENU/?guid=Bifrost_Common_install_compounds_and_graphs_html
- This release removes several compounds and graphs that are now shipped with Bifrost, including get_geo_property_or_default, normal_and_tangent_to_orientation, and point_scope_rev3, set_mesh_uvs.
- It also removes scatter_points, and has a hidden node called scatter_points_legacy, as Bifrost now contains a node with the same name.
- distance_to_instances measures distance to instanced geometry using geometry queries.
- scatter_points_in_gaps scatters using blue noise between other instances, avoiding them.
- Several new field-based influences, including aero_pyroclastic_influence, aero_noise_transport_influence, aero_erode_density_influence, aero_einstein_influence from the FX team.
- Fixed sort array and remove duplicates for cases of empty arrays
- Replace update_face_tangent with faster version
Jonah Friedman
Bifrost Product Manager
