Rebel Pack 0.4.0 for Bifrost 2.2 Released!
jonah.friedman
Community Manager Community Manager
jonah.friedman
We have a new rebel pack for you! This version of the Rebel Pack, 0.4.0, works with Bifrost 2.2 and later versions.
https://area.autodesk.com/downloads/rebel-pack-040/
How to install compounds and graphs: https://help.autodesk.com/view/BIFROST/ENU/?guid=Bifrost_Common_install_compounds_and_graphs_html
  • This release removes several compounds and graphs that are now shipped with Bifrost, including get_geo_property_or_default, normal_and_tangent_to_orientation, and point_scope_rev3, set_mesh_uvs.
  • It also removes scatter_points, and has a hidden node called scatter_points_legacy, as Bifrost now contains a node with the same name.
  • distance_to_instances measures distance to instanced geometry using geometry queries.
  • scatter_points_in_gaps scatters using blue noise between other instances, avoiding them.
  • Several new field-based influences, including aero_pyroclastic_influence, aero_noise_transport_influence, aero_erode_density_influence, aero_einstein_influence from the FX team.
  • Fixed sort array and remove duplicates for cases of empty arrays
  • Replace update_face_tangent with faster version
Jonah Friedman
Bifrost Product Manager
g2m.agent
Hello jonah.
Because the new version of Bifrost has its own "scatter_points" node, the scatter points of "Rebel Pack 0.3" have been renamed. This caused the previous simulate_lightning becomes unavailable.
I suggest that we should develop a compound naming rule, adding the abbreviation of our own name before the compound. Such as:
scatter_points => Reb_scatter_points
memory_cache => Reb_memory_cache
If everyone follows this standard, conflicts will be greatly reduced.
I cannot use simulate_lightning in Rebel pack 0.4 I cannot seem to find the rebel pack 0.3 for download and the direct link redirects to 0.4 Is there any way to download 0.3 version or can i make an edit in 0.4 to make the simulate lightning work???
Christoph_Schaedl
I uploaded v3 here.
https://forums.autodesk.com/t5/bifrost-forum/bifrost-develops-lightning-tool-demo-1/m-p/9974892#M417...
https://linktr.ee/cg_oglu
batarg
is there any updates of rebel pack for new bifrost 2.3.1 version?
Christoph_Schaedl
0.4.1 is the latest and does work with 2.3.1 Bifrost
 https://area.autodesk.com/m/jonah-friedman/assets/rebel-pack-041
batarg
thank you very much!
