points flow on surface
darioOrtisi
Message 1 of 9
darioOrtisi
Hi there. As the title i will like to create some effects. I want the scatter generated from mesh, to move on the surface itself. I 'm trying to connect a lot of nodes(i dont' have an idea of what most of the nodes do)
I image scatter point, emitting particles on the surface, but still over the surface, controlling the movement by noise or curl. Thanks to anyone can help me.
Dario
Replies (8)
Message 2 of 9
darioOrtisi
Hello. Does anyone have an idea?
Look at this great work done by Sachin Shrestha, but i have no idea of the connected nodes and the iterations.
https://twitter.com/i/status/1306138764696342528
Message 3 of 9
to-to-ro
Its can be done easily.
Here is example
Anton Kalchenko
Message 4 of 9
to-to-ro
Little update: direction vector
Anton Kalchenko
Message 5 of 9
to-to-ro
And finally its possible to add some noise
Anton Kalchenko
Message 6 of 9
darioOrtisi
Thank you very much. It's great help.
In order to do the noise, i can understand that is inside the compound that all do. I'll try to add noise on the position of compound. But with no luck.
Anyway Thanks
Message 7 of 9
to-to-ro
There is plenty of ways
One of them in attachment
Anton Kalchenko
Message 8 of 9
darioOrtisi
hi @to-to-ro
I'm back to answer another question. I 've try before a lot of times but with no results. How do i set the size of point based age and how do i set the age of the points, so at certain frame it begun to disappear.
Message 9 of 9
darioOrtisi
I'm able to figure out how to do a variable size, but it grow infinite. Any advice?
