Meshing Plexus Effect?
johnbUS775
johnbUS775
I want to generate a mesh using the Plexus effect. So, having some control to create meshes between the generated points. This is the kinda effect where I can shade some of the faces between the points.
This is my current test setup, just points from a sphere being deformed with a curl noise.
I assume it's using the create mesh node and possibly with the nearest point in radius, but I can't figure it out.
sepu6
You gotta thinking it a little bit different instead of using the plexus node here as it is.
Create a geometry > triangulate it > delete randomly some points > convert the mesh to strands and basically there you go. you can also copy sphere to the points + the layer the plexus node on top of that.
