Maya Hair to Bifrost Strands Instancer
sachin.shrestha
sachin.shrestha
Here is a quick little example of how you can use the latest Bifrost 2.2 version to "import" Maya curves into bifrost and do some interesting rigging/cfx workflows with it. In this example, I use the nHair output curves as strands input in a bifrost graph that instances objects along the strand tangents.
You can check the attached scene file for the workflow. The free rebel_pack and MJCG compounds are required to open the scene correctly.
Cheers,
Sachin
Christoph_Schaedl
Ooh man its goin on to much. I cant follow anymore.
Thanks for sharing all your R&D.
https://linktr.ee/cg_oglu
may I ask if the example file you shared is working correctly? somehow, the bifrost node on scene does not seem to exist ( with rebel_pack and MJCG compounds ). If you do not mind, can you check?
mjcg91
Hi @Anonymous ,
The scene from @sachin.shrestha was using an older version of MJCG compounds was not forward compatible with 2.0. I updated it to work with the latest version. I attached Sachin's scene working with the latest MJCG compounds version.
The only difference is that the instance geometry must now be facing the positive Z axis instead of the positive X axis.
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
