Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Maya Hair to Bifrost Strands Instancer
3 REPLIES 3
sachin.shrestha
1304 Views, 3 Replies
Here is a quick little example of how you can use the latest Bifrost 2.2 version to "import" Maya curves into bifrost and do some interesting rigging/cfx workflows with it. In this example, I use the nHair output curves as strands input in a bifrost graph that instances objects along the strand tangents.
You can check the attached scene file for the workflow. The free rebel_pack and MJCG compounds are required to open the scene correctly.
Cheers,
Sachin
Labels (1)
3 REPLIES 3
Ooh man its goin on to much. I cant follow anymore.
Thanks for sharing all your R&D.
https://linktr.ee/cg_oglu
in reply to: sachin.shrestha
may I ask if the example file you shared is working correctly? somehow, the bifrost node on scene does not seem to exist ( with rebel_pack and MJCG compounds ). If you do not mind, can you check?
mjcg91
Hi @Anonymous ,
The scene from @sachin.shrestha was using an older version of MJCG compounds was not forward compatible with 2.0. I updated it to work with the latest version. I attached Sachin's scene working with the latest MJCG compounds version.
The only difference is that the instance geometry must now be facing the positive Z axis instead of the positive X axis.
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
Technology Administrators
