Hello everybody ,
is there a way to manipulate(translate, rotate and scale) VDB from inside Bifrost graph?
Solved by morten.bojsen-hansen. Go to Solution.
Any VDB loaded into Bifrost (e.g. with read_OpenVDB) will be converted to Bifrost's volume tile tree which can be manipulated easily with our volume toolkit (see e.g. resample_volume for translate, rotate and scale). You can then save that manipulated volume back out using write_OpenVDB. However, this is technically not modifying the VDB directly.
thanks @morten.bojsen-hansen ,
I tried (resample_volume), linked it to a locator for manipulation, but found to be heavy to deal with,
after using (resample_volume) the viewport feels sluggish,
I was curios if there is something as fast as manipulating "aiVolume" in the scene?
thank you for your reply.
@HasanDiab , Sadly not yet. We do not (yet) support transforms in Bifrost, so any transform will have to be applied explicitly for the time being.
Thank you @morten.bojsen-hansen,
I will consider (Resample_Volume) as an accepted Solution for now,
hope to get better manipulation later.
