I can't set a port iteration target inside for_each
mcw0
Advisor Advisor
mcw0
It's been awhile since I've had a chance to dive back into Bifrost.  But when I right click on my input, I can set the port iteration target to true.  But I seem to recall I can set what output it is grabbing.  But I'm not getting that option inside the for_each node.
I also notice a "Set port iteration counter".  I've never had to deal with that before when accessing previous values.  Setting that to "True" doesn't allow me to select which output value I want to grab for the next iteration.
I want to add to a previous value each time the for_each node advances to the next index.  Is there another way other than the iteration target?
Christoph_Schaedl
Have you seen the for each intro from frosty?
https://youtu.be/pA9Ra0KMg5w
https://linktr.ee/cg_oglu
Christoph_Schaedl
And the one from Yingying?
https://youtu.be/Rj5L7azXogo
