How to use Custom_Scstter_CGS
kss-21130056
kss-21130056
https://youtu.be/edcC7ojZW0Q?si=h-KyZ-dhoTLFJPsc
This video has a node called Custom_scstter_cgs, which I think is probably from this URL [ https://cgside.gumroad.com/l/custom_scatter_cgs ].
How can I use this as a node?
Christoph_Schaedl
Reading the description below the video.
And follow the instructions on how to install .
https://help.autodesk.com/view/BIFROST/ENU/?guid=Bifrost_Common_install_compounds_and_graphs_html
https://linktr.ee/cg_oglu
kss-21130056
The problem has been solved. Thank you.
