How to kill particles that intersect geometry?
velariakrah2002
velariakrah2002
The MPM GEL emitter emits particles. There's geometry underneath. When the particles reach the geometry and intersect it, they should die. How do I do this? I can't find any guides, and the GPT chat doesn't explain how to make nodes either.
sepu6
you can use a mask  + a kill influence to do that - where in the mask you cube input will be and make sure you pick Mesh in the geo shape of your mask node
velariakrah2002
It doesn't work. Did I do everything right?
sepu6
just check absolute on the kill influence
velariakrah2002
I've encountered a problem. The method recommended above is putting a significant load on the simulation processors. Is there a simpler way to kill particles in a specific area?
sepu6
then use a kill plane
