How to create QuadChamfer with the bifrost graph editor?
Mike_Isaakidis
Mike_Isaakidis
So I kinda understand the steps involved on how the procedure should work, but I dont know how or which nodes (or if they even exist) to connect together in order to make this work.
Basically:
1. You input any model
2. Select all hard edges
3. Perform a bevel.
Then you output the bevel amount, the bevel segments and the visibility of the final outcome.
I am new to the graph editor so if anyone has any pointers I'd really appreciate it.
Cheers
-Mike
joostkonemann
There are no higher-level modelling compounds in Bifrost yet. So, no pre-made bevelling compound.
You may be able to build it from scratch with the low-level nodes.
MacBook Pro 13,3 - 2.7GHz - 16GB - Radeon Pro 460 - macOS Catalina 10.15
