How to create custom enum attribute that can be read in the bifrost graph?
mcw0
Advisor Advisor
mcw0
OK, I thought I had the solution with "addAttr".  That creates the attribute.  But I can't access it in the graph.
I want to add a "method" attribute to my bifrostGraph node with "Inward", "Outward" and "Bidirectional" as options.  But when I create a "value" node, under the "enum" option are only predefined values.  And "Custom" isn't custom at all.  Or at least I'm not making sense of how to use it.  How do I create my own?
suryamunny
here is the detail explanation from maxime on his blog.
https://maximejeanmougin.com/2020/07/21/enum-in-bifrost/
mcw0
Thank you for that link.  It's an involved process.  Thanks Maxime for the blow-by-blow.
