Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
How do i mute a Bifrost Graph?
10 REPLIES 10
Message 1 of 11
Christoph_Schaedl
1330 Views, 10 Replies
Id like to turn the calculation off from time to time.
Whats best way to mute a Graph?
https://linktr.ee/cg_oglu
10 REPLIES 10
Message 2 of 11
cntrl+. will pause the graph.
Message 3 of 11
Ctrl-period (.) or Command-period (.) on Mac.
https://help.autodesk.com/view/BIFROST/ENU/?guid=Bifrost_Common_build_a_graph_pause_graph_html
MacBook Pro 13,3 - 2.7GHz - 16GB - Radeon Pro 460 - macOS Catalina 10.15
Message 4 of 11
mjcg91
in reply to: Christoph_Schaedl
You can use "Pause Graph Compilation" http://help.autodesk.com/view/BIFROST/ENU/?guid=Bifrost_Common_build_a_graph_pause_graph_html
Another way to mute something is to use an "if" node. You plug your graph's output connection in the "true_case" input, and just use the condition to control whether or not a graph branch should be running or not.
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
Message 5 of 11
aberkstein
in reply to: suryamunny
I would love to change the shortcut of this to something different, please add this functionality... those 3 keys are too much for something I find myself constantly doing....
Message 6 of 11
Hello all, is there a way to mute only spesific node in bifrost graph ?
Message 7 of 11
sepu6
Not yet .... Hopefully, this will be added since it has been asked quite a few times.
Message 8 of 11
As some clever brains pointed out that isnt so easy. Cause muting some nodes would just break the entire computation.
Its easy to mute nodes in a linear graph like in nuke. But in visual programing you would just create non functional code.
For some nodes it does make sense. And it would be a great feature to have.
Message 9 of 11
2023. Maya 2024... Is by any chance this feature already implemented? In maya this is specially cumbersome.
Message 10 of 11
As mentioned above its not so easy cause it would just break the graph. Its not a priority feature.
You could branch out the graph to a terminal if you need to know the effect of a certain node.
Message 11 of 11
I understand that even removing a certain node in the chain might break everything ahead due to the autoports switching types by mistake. But how it can be muted in programs like Houdini or Blender just by muting a node? Isn't the equivalent to add a "if" node inside each node by default to work as a "pass" node?
Technology Administrators
