Have you ever made the "Fallout 4" mod? when you "publish", the Creation Kit can automatically list all other mods you referenced, so you can confirm the operating environment of your compound.
Does Bifrost have such a function?
Solved by mjcg91. Go to Solution.
No. You check open the .json file and check inside of it. All of the other .json dependencies are listed on the top.
This is fine too.
But it is difficult to judge where these compounds come from. if it comes from bifrost itself, then I can ignore it.
