Get Instances to face towards locator
m_lattner
m_lattner
Hello everybody,
I would like to make a little tool that allows me to scatter some kind of geometry over a plane, but I would like to control the rotation of each instance in such a way that each of the objects follows some type of controller (in this case, the locator).
I found the create_arrow_strands node, with which I am able to visualize the sort of behavior, but I can't come up with a solution to mimic this behavior with the instanced geometry.
I would really appreciate any sort of lead towards a viable solution.
sepu6
There are a few ways to do this, here is one way. You need to add the point orientation attribute which is a vector 4, then the instance will read that and react accordingly.
(view in My Videos)
m_lattner
Thank you so much, that is exactly what i was looking for!
