Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Geometry Intersection between multiple objects
1 REPLY 1
stnikou
152 Views, 1 Reply
I follow this tutorial: https://www.youtube.com/watch?v=HFE-wTw06kE&lc=UgwNRzz8GbGFA_3xr754AaABAg.9aeEb7Fnt-T9aeXu9xxb8e&ab_...
very neat and explanatory, it works perfectly if you have a static object and want to scope the intersections of other geometries into the static one.
But if you want to check all intersections between multiple selected objects (not between a static and many selected) how do you proceed?
Basically i will have to select all objects and drag them into Bifrost graph editor and then connect the input to a merge mesh node? Ideally i want all the object penetrations to be visible at once.
Any ideas how to proceed with this?
1 REPLY 1
Roland.Reyer
in reply to: stnikou
You can do the basic thing in a loop and test all objects against all others.
In the loop you would build an array from all points, that’s the result.
