The curves_influence Tool is updated! Support dynamic curve, add MPM example! Most of the parameters support advanced custom operations! Give the artist maximum control!
Please enjoy!
Demo:
Hi phil,
You should increase the value of "inherit_curve_velocity". I modified your file and hope it is the result you want.
Hi Bruce in Maya 2022.2, some of the scenes open, but scene k won't simulate. I've attempted to fix it but haven't found the solution.
Any tips for getting scene k working? I've attached images of scene k with the issue and the cache file, as well as scene c which appears to function correctly.
i try set the cache to write and change a new source_mpm_fluid it work, I guess some value he set to 0
thank you @tanshiekwei
After doing some more exploring in the nodes Bruce made, the values that seem to make it work again are:
-changing the mass density back up to something like 1000
-giving a value to the relaxation time
@Bruce.Lee. Perhaps you could shed some light on how the relaxation time works; I'm having an issue where the particles all freeze after a certain frame, and the only thing that seems to change it is relaxation time.
In my drive below are three playblasts showing different relaxation times and showing where the particles freeze in a 300 frame playblast, only thing changed per file was the relaxation time (.001, .005 default, .010). Is there something else that could be causing these freezes?
hello,
i tried to use bifrost 2.3.1.0 with the amazing curve flow....but i failed
