Constrain one MPM cloth to another one
verstaerker
verstaerker
maybe my question is a bit noobish .. i just started experimenting with bifrost graph :
I want to simulate a flower with petals.
So i have one geo for the stem and one for the petals  , wich both should have different attributes - the stem is more stiff and the petals very soft.
Hoe can i stick the one cloth to the other one ? I know how i can constrain the stem to the ground but i don't know how the petals can be constrained  to the top of the stem, wich moves a bit from the sim
verstaerker
this is actually super simple using traditional ncloth and compound constraints ... i'll use that for now . If one knows how to achieve this in bifrost-graph , that be great to know
mspeer
Hi!
Just connect multiple cloth_source outputs to the mpm_source input of a constrain_mpm node (this even works without any constraint_geometry connected).
verstaerker
i guess that was to simple .. thanks!
