Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Building uv's for a bifrost mesh
3 REPLIES 3
blaabjergb
1083 Views, 3 Replies
blaabjergb
Hi guys, I am trying to do unitize on an input mesh and then doing a layout with each face uv’s next to each other in a neat line/grid, but I am stuck with what kind of data I need to input into the set geo property.
I attatched the file for reference.
I am constructing a mesh based on an input, but I need to rebuild the uv’s.
I can pass through the original geo uv’s but that’s not what I want.
I have the faces of the mesh split up so no face shares the same uv’s, but I absolutely can’t figure out how to build an array that the set geo property will take, and the set_mesh_uv’s would only work if I knew the order of uv’s, but I am kind of working in the blind with this.
Bjorn
Bjorn
Tags (2)
Labels (2)
3 REPLIES 3
jonah.friedman
in reply to: blaabjergb
jonah.friedman
Hi Bjorn,
Here's something that might help you, from the set_mesh_UVs docs.
indices
The per-face-vertex indices that map a face vertex to an element in the given coordinates array. If empty, the coordinates are treated as per-vertex values, and the mesh's face_vertex array is used to index into the coordinates array.
In order words, you can provide per-point UVs if you don't supply any indices and it'll create the indices for you.
If you want to create UVs per face-vertex, it's also simple. You only need indices that count up to the number of face vertices.
For example, a cube has 6 faces, 8 points, and 24 face vertices (6 quads with 4 points each). To set per-point UVs, you can just supply an array of 8 uvs and no indices. For face vertices you can supply an array of 24 uvs + "identity" indices [0,1,2,3...22,23] (which you can create simply with "get array indices").
Jonah Friedman
Bifrost Product Manager
Hi Bjorn,
indices
Jonah Friedman
Polytikal1
Polytikal1
How do you pull the UVs from an alembic cached mesh (cached on maya, not bifrost)? I can't seem to make it work on bifrost graph editor...
morten.bojsen-hansen
Please don't resurrect old threads with unrelated questions. It's better to create a new question.
