Dear community,
I've got an error while trying to use BOSS on my project. The issue is that the BOSS editor doesn't appear and the program shows me an error (you can notice it on the screenshot). What shall I do?
Solved by Grahame_Fuller. Go to Solution.
Is the Boss plugin loaded?
Is it loaded in the plugin manager?
Boss.mll
This sounds similar to an old bug that has been fixed. I suggest that you install the latest version of Bifrost for your version of Maya and OS from the Download Center.
The workaround in the old version was to open the Boss Editor in a new scene, leave the window open, and then open your saved scene.
I hope that helps,
gray
