Hi Everyone,
my first post here. I approched to Bifrost just few weeks ago, and I have a question: how can I obtain the average of an array that contain coords?
I have 2 intersecting objects, a vertical plane and an horizontal cylinder to create an irregular section. I want to track the nearest point of the plane on the cylinder surface, obtaining a single point as average and next using it to set translations of another geometry. At this time I've solved only the problem about projecting point on the surface (see attachment). I've not found a node that return an average, so I think the best way is to use an iteration after my sample property node. I've just watched the tutorial by Jonah Friedman (https://forums.autodesk.com/t5/bifrost-forum/introduction-to-bifrost-iteration-tutorial/td-p/8949069) but I can't get it work, maybe I am missing something. Please, someone could help me to connect properly nodes inside the iteration or suggest other solution?
Best.
Giulio.
