Hi all,
I am currently having a problem after installation of bifrost plugin Bulletfrost by the great HeydoubleU
I get this messages:
// Warning: Warning: Could not load shared library 'BulletfrostOps' from path 'C:/Users\bruno\Autodesk\Bifrost\Compounds\Bulletfrost\lib'.
// Error: Error: Default value function not found for value of type 'Bullet::RBD::RigidBody'
// Error: Error: Default value function not found for value of type 'Bullet:๐ฅ:CollisionShape'
// Error: Error: Default value function not found for value of type 'Bullet::Constrain::Constraint'
// Error: Error: Default value function not found for value of type 'Bullet::BulletScene'
// Error: Error: while compiling top level compound 'bifrostGraphShape1', around <no specific location>:
// JIT compilation used external symbol '??$getDefaultClass@VRigidBody@RBD@Bullet@@@Internal@Amino@@YAAEBV?$Ptr@VRigidBody@RBD@Bullet@@@1@XZ' which could not be resolved
// Failed finding library for symbol ??$getDefaultClass@VRigidBody@RBD@Bullet@@@Internal@Amino@@YAAEBV?$Ptr@VRigidBody@RBD@Bullet@@@1@XZ
// Failed finding library for symbol ??$getDefaultClass@VConstraint@Constrain@Bullet@@@Internal@Amino@@YAAEBV?$Ptr@VConstraint@Constrain@Bullet@@@1@XZ
// Failed finding library for symbol ??$getDefaultClass@VCollisionShape@Collision@Bullet@@@Internal@Amino@@YAAEBV?$Ptr@VCollisionShape@Collision@Bullet@@@1@XZ
I have maya 2024 installed with bifrost 2.7, the message i get is surely related to the plugin installed but I am not sure how to tackle this.
I have followed Cristoph Schadl directions on installing the plugin
https://www.youtube.com/watch?v=HAHfqk7Z7u0
and here the links to plugin https://github.com/HeydoubleU/Bulletfrost/tree/master
Any help would be massively apreciated, not a pro with Bifrost but i am loving it so far
Many Thanks,
Bruno
Solved by Christoph_Schaedl. Go to Solution.
Maybe the latest version does only work for Bifrost 2.8
Could you post what you wrote in the maya.env file here?
Hey Cristoph, Thanks a lot for quick reply. I updated My bifrost to 2.8 and it worked! Thank you!
