Bifrost Aero and Vray
daniel9HCWR
Message 1 of 10
daniel9HCWR
I can get my head around rendering bifrost aero with vray? My VFB is empty when i render? Does anybody know how to assign shader?
In the vray documentation its refered to a vray attribute but it does'nt appear in my attribute panel when i select my bifrost node in the outliner?
Anyone managed this that could help me?
/Daniel
Replies (9)
Message 2 of 10
Christoph_Schaedl
Vray cant render Bifrost Aero. You need to export a VDB.
https://linktr.ee/cg_oglu
Message 3 of 10
daniel9HCWR
Noob question maybe, but what is a VDB?
Message 4 of 10
morten.bojsen-hansen
OpenVDB is a file format for sparse volumes. You can export them from Bifrost using the write_OpenVDB node.
Message 5 of 10
daniel9HCWR
How does the write node work? It doesnt seam to write anything?
Message 6 of 10
sepu6
Message 7 of 10
@daniel9HCWR at least on the of the outputs (on the right hand side of the node) of the write_OpenVDB node has to be connected to either an output node or a terminal for the write_openVDB node to execute.
Message 8 of 10
daniel9HCWR
Okay, i thought the writing was an alternative output.
The linked youtube-clip showed a method using file-cache node between simulation-node and output.
What is the difference between these to methods?
Message 9 of 10
The file_cache node just wraps up several of the write_XYZ nodes into one node. You can check this yourself by diving into the node. Personally, I prefer to use write_OpenVDB directly since it give the most control.
Message 10 of 10
damaggio
Just cache your VDB file and upload in a Vray volume grid for rendering.
