Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Bifrost 2.2.0.1 | scatter_point Node Error
11 REPLIES 11
Message 1 of 12
1334 Views, 11 Replies
I just wanted to test with full anticipation Maya 2020.4 with the latest Bifrost version 2.2.0.1.
I'm particularly interested in the new scatter_point node in this update, and I wanted to jump right into an example similar to the one in the Lights, Cameras, FX: Exploring What's Possible with Bifrost presentation.
Unfortunately, I get an error when creating the node (see screenshot).
Can anyone tell me if this is a user error or what I can do to get this to work?
Greetings,
Hermann
Greetings,
Hermann
11 REPLIES 11
Message 2 of 12
doppelgaenger_digital
Same here. I get the same error and I am missing some nodes listed in the documentation, such as scatter_points_blue_noise.
Also I am not entirely shure, if there should also be a scatter pack section when pressing tab, which isn't there. I thought I have seen it before...
Message 3 of 12
klaudio2u
klaudio2u
Works fine on my end when i simply connect polyPlane to scatter points node.
Also, blue noise is available under "Scatter Mode".
Message 4 of 12
Blue noise is under scatter node indeed, but in the docs there is a seperate blue noise node. I don't know if it should be there or not.
FYI: The scatter node with those errors has a number of inputs at the bottom, which are listed seperately after properties dropdown. I can post a screenshot later.
Message 5 of 12
tig4
tig4
Having issues with the scatter node also, as I'm following the Bifrost VP Masterclass. I may just be missing somthing, but all my errors look to be related to the scatter node, so posting here, hoping to find a solution. Thanks
Message 6 of 12
here's the scatter node with errors. The graph is not edited. That's the default state of this node.
Message 7 of 12
pivotgeeks
pivotgeeks
getting same error.
Ok i deleted my compund folder and then downloded and recopied new rebal pack4.0, now scatter point node works. i am getting same like  @klaudio2u  screenshot
like maya tradition we have to clean our preferance file 😄
getting same error.
Message 8 of 12
mihirsbcc
mihirsbcc
Same over here
Same over here
Message 9 of 12
mihirsbcc
in reply to: mihirsbcc
mihirsbcc
I am going to try it again. I found masterclasses confusing as many of them are made more than a year back. Some parameters have different names.
Message 10 of 12
Ok, I found the issue.
I thought I had reinstalled everything cleanly, but I had forgotten the User Compound directory where an older version of Rebel Pack was installed.
This caused the error.
So if you have a similar problem, delete the user compounds.
Can be found at:
  • Windows: /Users/usernameAutodesk\Bifrost\Compounds
  • macOS: /Users/username/Autodesk/Bifrost/Compounds
  • Linux: /home/username/Autodesk/Bifrost/Compounds
Best,
Hermann
Can be found at:
Best,
Hermann
Message 11 of 12
mihirsbcc
mihirsbcc
Thanks, while searching for compounds, I put all the rebel pac compounds
that include rebel pack 4 and now the scater_point compound is different. I
mean it has more inputs.
I opened the SNOW_SHADOW example and got the error message . with
scatter_poinrts.
scatter_poinrts.
Message 12 of 12
mihirsbcc
mihirsbcc
I have both rebel pack 3 and 4. I will remove the 3 and while searching for a specific compound which was in rebel pack 1?....  got to clean up my house.
