Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
bif_particles to create_instances issue
12 REPLIES 12
Message 1 of 13
xianwu_liu
616 Views, 12 Replies
Hi, I am try to use Aero bif cache to create instance with different object.
So I use read_bif_particles and create_instances nodes in bifrost graph to make it.
But for some reason the particle id didn't been read or someting, instance randomize_scale and rotation keep changing in every frame.
only
Any idea about this?
12 REPLIES 12
Message 2 of 13
sepu6
in reply to: xianwu_liu
Can you post a scene, maybe just like 5 frames or so?
Anyhow if you have an ID that is consistent make sure you connected in the `instance ID override`
Message 3 of 13
xianwu_liu
in reply to: sepu6
Thanks for reply, here is the playblast
Message 4 of 13
sepu6
This does not help me to help you though I see that you pts are jumping. Did you try what I said above? If that does not work, post a scene not a playblast.
Message 5 of 13
xianwu_liu
in reply to: sepu6
Sorry about that, I misunderstood.
Here is the attached file.
By the way, I couldn't find the instance ID override attribute to connect, so I didn't try it.
Thanks for the help.
Message 6 of 13
sepu6
So as I mentioned, you need to get the point id from the pts and connect that to the instance id override. Here is a fixed file for you.
Message 7 of 13
xianwu_liu
in reply to: sepu6
Wow it's working, thanks a lot!  However, there's another issue.
My rendering engine doesn't support rendering Bifrost graphs directly, so I need to export them somehow to Maya particles or MASH.
I've tried these two solutions, but it seems I can only get the position information and nothing else
(size, id, rotation etc).
https://www.youtube.com/watch?v=h73jTnokoM8&t=2s&ab_channel=AndreaPinto
https://www.youtube.com/watch?v=CB2TSgdEJPo&t=169s&ab_channel=HyUU
Here is my files and plugin in attached, could you let me know any idea about this?
Maya plug-in and Bifrost compounds available here: https://github.com/HeydoubleU/MeshToParticles
Message 8 of 13
sepu6
What render engine are you using?
Message 9 of 13
xianwu_liu
in reply to: sepu6
I am using Octane to render.
Message 10 of 13
sepu6
I can look it up later, but the heydoubleu plugin should work it should transfer, point_size, rotation, etc just make sure you are following correctly what he is saying.
Message 11 of 13
xianwu_liu
in reply to: sepu6
Thanks, I will check again as well.
Message 12 of 13
xianwu_liu
in reply to: sepu6
BTW I just notice the point scale and rotation still jumping every frame.
Could you please let me know how to fix it?
Message 13 of 13
sepu6
Then just set the point_id on the pts so the seed does not change. Like this - without the override.
Make sure to type the property correctly
