Adding the quaternion_to_axis_angle or quaternion_to_rotation_vector nodes to a bifrost graph and then attempting to publish the graph causes Maya to segfault. (Maya v2020.4, Bifrost v2.3.0.0, Linux CentOs 7.9.2009)
Interestingly, if I explode any quaternion_to_axis_angle nodes contained therein to their constituent parts, publishing does not cause maya to crash. Even grouping them again into a compound still works.
Solved by Grahame_Fuller. Go to Solution.
We've reproduced this issue and are tracking it as BIFROST-6396.
Thanks for reporting!
gray
Just to give an update: This was caused by the same underlying issue as another item (BIFROST-6216 Publishing: Crash during compound re-publishing).
It has been fixed in our internal builds, so stay tuned!
gray
