Some text and Lines is not showing in Trueviewer, but is showed anywhere else.
jannik_christiansenY6NBY
Message 1 of 9
Hello
i have an issue, where i cant see specific lines in some cases polylines and text in off page connector in Plant 3D.
i have looked into the souce drawing if:
- Proxygraphics is set to 1
- Proxysho is set to 1 (regan afterwards)
- checked if any are set in any layers, there is not shown.
The thing is we can see these lines and text in, PDF and in the source 2D dwg. but not in the Trueviewer why?
Replies (8)
Message 2 of 9
paullimapa
could you share a sample dwg where this problem is happening?
Paul Li
IT Specialist
@The Office
Message 3 of 9
Hello @paullimapa
of course, here is an example. you can see there is missing text in the off page connector and a line in a valve for example QM4.
there is other text in other symbols there is missing too, as you can see.
Message 4 of 9
paullimapa
Can you also share the actual dwg file here?
Paul Li
IT Specialist
@The Office
Message 5 of 9
hi @paullimapa
of course, i had to make other example as i am not aloud to send the first drawing out.
but the same thing happens on this one.
Message 6 of 9
pendean
Community Legend
Community Legend
@jannik_christiansenY6NBY Thanks for the DWG file: your missing content is specialized content unique to Plant3D, I have the P3D Object Enabler installed for AutoCAD (left of screenshot) so I can see it just fine.
My observations: that same P3D Object Enabler did not install/ignored both DWGTRUEVIEW (right of screenshot) as well as AutoCADLT (middle of screenshot, and it has proxyshow and proxygraphics on), so it appears the DTV limitations are deliberate by Autodesk and there is nothing we end users can do about it other than export from P3D to create a new DWG file (bottom screenshot)
OR start using the online Autodesk free viewer instead
https://viewer.autodesk.com/
Message 7 of 9
hi @pendean
this could very much be it, we run 2024 on all our Autodesk line up.
is there anyway i can check if this object enabler is active or even installed? as i can see that, that it should be included in the installments in 2024.
Message 8 of 9
pendean
Community Legend
Community Legend
@jannik_christiansenY6NBY Visit your Autodesk Accounts page and download the year-specific Object Enabler you need from there
Message 9 of 9
manieshkumar.suresh
When the application that created the custom object is not available, a proxy object is substituted in its place.
To change the value of the variable, so that proxy images of the AutoCAD Plant 3D objects are saved, follow these steps:
  1. Open the DWG file in AutoCAD Plant 3D or AutoCAD vertical.
  2. On the command line, enter proxygraphics
  3. When prompted to enter a value, enter 1
  4. Save the file.
When you open the file in DWG TrueView, the AutoCAD Plant 3D objects will be displayed.
The value of the AutoCAD variable PROXYGRAPHICS controls whether images of proxy objects are saved in the drawing:
  • 0  - An image is not saved with the drawing. A bounding box is displayed instead.
  • 1  -  An image is saved with the drawing.
Refer this article - https://help.autodesk.com/view/TRUEVIEW/2026/ENU/?guid=GUID-E0433EE8-B8B3-4143-8474-7F1A1EF7F7F8#GUI...
Maniesh Kumar Suresh
Escalation Lead
If this information was helpful, please use the Accept as Solution function — it helps other users.
