- Mute
- Permalink
- Report
Hello, I'm running AutoCAD 2008 and Excel 2010. I usually recive embedded dwg files in spreadsheets, and edit them by double click on them.
I didn't have problems until I installed DWG trueview 2010. Then these Ole objects, started being named as DWG TrueView Drawings (instead of Autocad Drawing as before), and can’t be edited double clicking them.
If you try to do this, a message box with the text "Cannot start the source application for this object" pops up.
I tried uninstalling Dwg TrueView 2010, and reinstalling autocad but it didn’t work.
I've also started with a new Excel sheet and new Acad drawing thinking there might be a version incompatability but I still get the same error.
If somebody had the same problem and found a work around, i will apreciate a lot the feedback.
