Print Failed
Print Failed
Print Failed
Design Review 2012 wont print any DWF or to any printer.
It has be uninstalled, reinstalled, repaired and printers reinstalled with no change.
There are no application logs or further explanation of the error anywhere that I can find.
Help would be appreciated.
ThinkPad Core i7
Windows 7 Pro
Administrator
Thanks.Print Error
This problem was resolved by deleting the MRU list in the windows registry, found here: HKEY_CURRENT_USER\Software\AppDataLow\Software\Autodesk\Design Review\Preferences\FileOpen
I was hopping that this issue with printing would be resolved from 2011, but apparently AutoDesk chose to change the way it reported errors rather than fixing the issue of corrupted MRU listings.
AutoDesk, please get your act together.
When you say delete the MRU List are you talking about the folder on the left side of registry or the individual entries on the right side of the registry that appear when you click on the folder?
Thanks.
In the MRU list delete all the entries. I only have (1) right now.
Clearing this list helps resolve a lot of issues with Design Review. There is likly something wrong with the code that parses this list on startup or anytime the program does something with a file as clearing this list solves a whole host of weird errors.
It is the frist thing that I do whenever I'm having trouble with Design Review.
Worked like a charm.  Thanks!
