Yes, that was a typo. The plan sheets read S1-1, S1-2, etc. I appreciate
all of the comments. It has been extremely frustrating to satisfy all
members involved. One of the major problems has been the inconsistency. We
have had contractor who went out of their way to call us and tell us how
good our plans are, but we have had other contractors who were just confused
by them. The same thing has been true with engineers. I worked with a
civil engineer on a specialized job who never complained once. This
structural engineer just has a had time understanding what is going on. We
have to call him on the phone and explain which sections he needs to look at
etc.
From the posts I can see that I must need to give a little bit. It
would be nice to "say it only once," but that method is not as excepted as I
thought it was. While I am at it, dose anyone ever use 3D representations to
clarify plans for the consultants and contractors. I had the far fetched
idea of including a 3D representation of each plan. It would almost be like
a key plan or something but in ortho. Like I said that is pretty far
fetched, but our buildings are quite complicated and what seems clear to us
is almost impossible for other to see, (mentally).
Jonathon
"Charles Prettyman" wrote in message
news:5559A39B5963D6F4070583DE961C3A45@in.WebX.maYIadrTaRb...
> I think that you have a typo in how you described this - you list two
> different sheets S0-1. And that, to some extent, shows why some people
> prefer simple sequential numbering of sheets. With sequential numbers,
> there is no "wrong Number" while with a systematic numbering scheme, it is
> possible for a sheet to have the "wrong number"
> However in large sets (beyond what I would expect to see in a 5,000 SF
home)
> a system such as you describe can be very helpful for finding the right
> sheet. The trick is to find a system that is appropriate to the most
common
> size work you do, and adaptable to to both the largest and smallest jobs
> yoou have. I do think that if you are going to use systematic numbering,
> you should do it on all jobs. It is just simpler, I believe to use the
> system all the time, or none of the time.
> And, if I understood your system, (and interpretted the typo correctly), I
> think it is probably a reasonable system for the work you are doing.
> I have noticed, incidentally, that Architectural firms frequently use
> systems to number their sheets, while consulting engineers generally do
> not - at least with the size project that I mostly work on - 15 - 25,000
SF
> restaurants.
> As far as duplication of notes, some duplication is almost unavoidable.
My
> own rule of thumb is that if a drafter needs the note to understand what
> he's drawing, the guy in the field is certainly going to need the note to
> understand what he's looking at. But, that doesn't mean you need to repet
> everything. Label things, and refer back to the plan for more info. That
> should address your engineers concerns (which are valid) at least in part.
> "Giebeler" wrote in message
> news:7B2B04B4E62D5FAADA14E8F6BDFFD52A@in.WebX.maYIadrTaRb...
> > We are having problems with our structural engineer and I thought
all
> of
> > you may be able to give me a general idea of what is expectable. Any
> > response will be extremely appreciated. I am hoping to get the largest
> > possible response to this message so that I can print them and use them
to
> > find a general consistence among others in the field.
> > We are a residential design firm doing higher end custom homes,
> (usually
> > about 3,000 to 5,000 sqft). We have recently adopted the NCS system.
We
> > now currently use NCS title blocks, sheet and file numbering systems,
> > keynotes, etc. Also, to keep drawing time down and accuracy up I have
> been
> > trying to limit information to one place, ("say it once and in the right
> > place"). Our setup for structural plans along with an explanation
> follows:
> > S0-1 General Structural Notes
> > these are general notes (basically specs), shear wall schedules, header
> > schedules, and some typical details.
> > S0-2 Typical Structural Details
> > just like it says. I am using this in an attempt to cut down on custom
> > details
> > S0-1 Foundation Plan
> > Here we have the foundation plan with detail references to footing
> > conditions, we are showing posts but are no calling out post sizes.
> > Additionally there are keynotes explaining special conditions, general
> > notes, and a key plan
> > S0-2 Structural Floor Plan
> > Here we are identifying framed walls with a legend and dimensioning
them.
> > We are also showing shear wall locations, calling out posts, beams, and
> non
> > typical header, (I am not calling out standard headers because of the
> header
> > schedule on S0-1). Additionally there are keynotes explaining special
> > conditions, general notes, and a key plan
> > S0-3 Roof Framing Plan
> > Here we show a full roof framing plan with every rafter drawn in. We not
> > direction of span and size and use masked text to identify major members
> > such as ridge boards, hips, valleys, etc. Additionally there are
keynotes
> > explaining special conditions, general notes, and a key plan
> > S3-1 Building Sections
> > Hear we call out braces, ceiling joists, plate heights, etc. Basically
> > everything that has not been identified in the previous plans.
> > S5-1 Structural Details
> > The structural engineer, (as well as a few contractors, and the
principal)
> > has complained about basically everything. They think that the sheet
> format
> > "S1-0" etc. is too complicated and would rather just use "1, 2, 3" etc.
> I
> > disagree because we typically have about 30 sheets and I like the extra
> > organization. "They" also don't like using 2 letters for details such
as
> > "A1", they would prefer a, b, c, d, etc. Again as a draftsman and
> manager
> > I like the extra organization.
> > The main problem is however the issue of "Saying it once and in the
right
> > place". The structural engineer wants us to duplicate the information
> shown
> > on the plans on the building sections. My problem is that I feel it
goes
> > against industry standards, it will push our drafting time up, and that
we
> > will be opening the door for errors. Plus the fact that since it has
> > already been noted and detailed on the plans it just feels wasteful.
> > So, what is everyone else doing? Are you duplicating, and where are you
> > calling specific information out? Thank you all for you time - it is
> > appreciated in advance,
> > Sincerely,
> > Jonathon Giebeler
> > David Abbott
> > Residential, Planning, and Design
