Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Looking for Answers for Toll Architecture AutoCAD Skills Assessment - Test
6 REPLIES 6
9761 Views, 6 Replies
I found this assessment at the following on line.
[DOC]AutoCad Skills Assessment - Autodesk forums
forums.autodesk.com/.../112/.../AutoCad%20Skills%20Assessment%20-%20Test.DOC
A window; A box; A rectangle; A viewport. Toll Architecture AutoCAD Skills Assessment. What's the easiest way to know if you are in PaperSpace mode? ____.
I have been looking for the answers but have not found them. I am pretty sure I got them all correct, but would like the answers because we may use this for new hires. Could you please help.
6 REPLIES 6
Darin.Green
Darin.Green
@Anonymous
This test is easy, and out dated... Many of the questions needs to be updated unless you're looking for baby boomers to take the assessment. Smiley Very Happy  Why not generate your own assessment questions around the work your company does and that relates to the job they're applying for...
The answer to you question:
A. Zoom Out <-- Only if the viewport isn't locked
B. Ask Someone
C. Look at the layout Tab <-- Only show if you're in model space or paper space not the mode.
D. Try Printing
E. Check Application Status Bar <-- Is the answer but doesn't exist on the assessment
Again, create your own assessment around tasks used on projects within your company.
Example 1:
What formula is used to find the Area of a room?
A. L x H x W
B. L + H + W
C. ΔL x ΔH
D. L x H <-- Answer
Questions like this would imply the user know how to check his work.
Example 2:
If there are two points {A & B} with the distance between them being 10 inches and the difference in elevation is 35, what is the elevation of point C at a distance of 2.5 from the point A (everything else remain the same)?
A. 3.5
B. 7.0
C. 8.75 <-- Answer
D. 9.25
Questions like this would imply the user has basic knowledge and understanding of Algebra.
If this information was helpful, please consider using the Accept Solution
@Anonymous
B. Ask Someone
D. Try Printing
Example 1:
A. L x H x W
B. L + H + W
C. ΔL x ΔH
D. L x H <-- Answer
Example 2:
A. 3.5
B. 7.0
C. 8.75 <-- Answer
D. 9.25
Thank you for your response. I am in the process of putting together an assessment for our company use, thought I could use a couple of those questions.
JERRY MIDDELSTADT | Design Drafter - Engineering
Coldspring
17482 Granite West Road | Cold Spring, MN 56320-4578
😧 320.685.4871 | C: 320.267.8883 | F: 320.685.5094
www.coldspringusa.com| jmiddelstadt@coldspringusa.comFollow us on Twitter | Facebook
This communication is intended only for the recipient(s) named above, may be confidential and/or legally privileged, and must be treated as such in accordance with state and federal laws. If you are not the intended recipient, you are hereby notified that any use of this communication, or any of its contents, is prohibited. If you have received this communication in error, please return it to the sender and delete the message from your computer system.
Coldspring
RobDraw
RobDraw
If you are not sure of all of the answers, don't ask the question or word it in a way that makes you sure.
I don't agree with @Darin.Green's response. A couple of his answers were not "correct" and they get away from the purpose of the assessment.
When testing new hires for proficiency in a program, you need to determine the qualifications you are looking for and focus on them. Keep it short, direct, and relevant to the tasks they will be doing.
Rob
Rob
Darin.Green
in reply to: RobDraw
Darin.Green
@RobDraw
Only one of the answers were partially wrong -> Example 1 should've been L x W ... My mistake... Smiley Wink
The purpose of an assessment is to determine whether or not a user can perform his/her job function. Kids in middle school can answer those questions... If you're only looking for a drafter for labeling and redline work, then your assessment may be ok.
Keep in mind, that's why many CAD Managers spend most of their time checking the work of every change made to the models, because they can't trust the efficiency of their staff.
As a CAD Manager, I require applicants to know more than just the application. It would be easier to teach them the application, rather the engineering that goes into it. There are too many applicants who doesn't know how to check their own work and rely solely on the calculations from the app and that's what companies should be looking for in my opinion.
@Anonymous - My point is that you should create your own assessment for applicants that fits your business needs while keeping the end goal in mind.
Good Luck!
@RobDraw
Good Luck!
in reply to: Darin.Green
Don't worry about the error, I knew what it was. I agree with the statement;"There are too many applicants who doesn't know how to check their own work and rely solely on the calculations from the app". It needs to go a little farther. I started drawing by hand with the T-Square, the parallel bar, the drafting machine and then to AutoCAD 2.6. What I am finding now is that applicants or even some beginning drafters "don't know what the are actually drawing". They are using the program to put lines, circles, etc. on the screen. I am looking for a way to not only test AutoCAD/Inventor skills but basic knowledge & the understanding of what they are asked to do.
RobDraw
RobDraw
I totally disagree. That is what resumes, interviews, and references are for. Most places hire good people quite successfully without even giving a CAD test. A good CAD test should come during or after the 2nd interview and will help you determine if potential candidates can perform the tasks required of them while using the program and if they can follow typical office procedures to help you determine the best candidate. In other words, a bit of an understanding of how they will work in your office's environment. Not to determine if they are a candidate.
Now, if someone gets through the interview process and cannot perform basic the AutoCAD functions required, it means there is something wrong with the interview process or the potential hire lied. If everything has gone well, everyone taking the test should be able to pass it in a number of ways. The way that they choose to do it can be a really good indicator of how much they know about the program.
For example, as part of the test, tell them to do something in a particular way that resembles a typical workflow for the position. They should get the right result.
They might hack their way through it. Not a good candidate
Or, they might do it the way that you told them to. A good candidate.
Or, they might show you a better way of doing it. Definite hire.
Something just dawned on me. The OP may have a different reason for the test. Possibly, needing it before the first interview to weed out people who are not qualified. If that is the case, I'm a little off base but not too far.
Rob
Rob
Administrator Productivity
