Energy analysis Icon disappeared
raaid.aldoury
Message 1 of 11
raaid.aldoury
Dear All
I have Energy analysis in my REVIT program 2017. I have tried to instal revit insight for solar analysis, it has beed added but energy analysis disappeared from program. First picture befor update and the second after
Accepted solutions (3)
Replies (10)
Message 2 of 11
Viveka_CD
Hi @raaid.aldoury
Thanks for participating in the Autodesk Revit forumSmiley Happy
Can you ensure that the energy analysis and tools tab is checked in your options - user interface settings?
If you find this post has solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome!
Thank you.
Message 3 of 11
raaid.aldoury
Hello Viveka_CD
Yes I checked it and you can see it
Thank you so much
Message 4 of 11
raaid.aldoury
Dear Viveka_CD
I checked it and you can see it here
Thank you
Message 5 of 11
krishnan.gowri
I am assuming you have 2017.2 or later.  Energy Analysis panel has been replaced with the Energy Optimization panel with newer features (but have the same location, energy settings and delete energy model options, along with newer buttons for generating and viewing Insights).  You do have the Energy Optimization panel to the left of the new panel  with E+ Loads, LAR and SAR.
Are you looking for any particular feature from the earlier Energy Analysis panel that is not present in the Energy Optimization panel?
Krishnan Gowri, Ph.D. FASHRAE, LEED AP
Principal Engineer
Generative Design Group
Message 6 of 11
Viveka_CD
Hi @raaid.aldoury
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks!
Message 7 of 11
raaid.aldoury
Dear Dr. Krishnan , I really thank you for your valuable answer
what I missed in new feature is the amount of Co2 emission due to electricity in consumption. In previous energy analysis it was given as it is explained in figure. now I can read the amount of co2 that is produced from fuel only.
I am not sure actually maybe I could not notice its value . but your answer encouraged me to use the new feature.
Message 8 of 11
mstein7484
Hi @raaid.aldoury
I'm not sure why you are unable to see the CO2 emissions for both electricity and fuel. I just ran a test case using Revit 2016 for the location of Santa Rosa CA USA and the service is reporting both electric and fuel in the Annual Carbon Emissions chart. What location are you using? Does it work for other locations for you?
Try the following:
  • log into www.gbs.autodesk.com
  • after logging in you will be taken to the projects list
  • cick on the project
  • click on the first run on the runs list view
  • on the Energy and Carbon Results tab, look for the Annual CO2 Emissions section below the Base Run on the left side of the page
  • Are you seeing the Electric and Onsite Fuel tons? This is the same information you should see in the Energy Analysis Results and Compare charts within Revit
Marjorie Stein
QA Analyst
insight.support@autodesk.com
Message 9 of 11
raaid.aldoury
Dear mstein7484 thank you for your response
I checked it and I did what you have said. I think it will be clearer in
attached image.
My location is Istanbul, Turkey.
Best regards
Message 10 of 11
raaid.aldoury
Hello Mstein   thank you so much for your response
I have done what you said. but unfortunately I could not found the value . My location is Istanbul,  Turkey. it can be  noticed  from picture  Electric 0.0 Mg.
Best regards
Message 11 of 11
mstein7484
When I entered Istanbul Turkey for the location (no specific street address) the service automatically applied the default location: Halaskar Gazi Caddesi 224A, Istanbul Turkey 34384, and used the weather station 1244217. I was able to get results for both electric and fuel.
Based upon your screenshot the third-party service that we use for CO2 emissions data (CARMA) did not provide us with data for a power plant for your location--thus you are seeing "NA" for all of the Carbon data on the right side of the screen. That data is required so that we know how to calculate the CO2 emissions from electricity use in your building. The sources supplying the electric plant impact the CO2 emissions impact the CO2 emissions for the electricity usage for your project. For example a large percentage of fossil fuels versus renewable energy used by the power plant will mean each kilowatt of electricity used in your building will emit more CO2 than if the power plant used less fossil fuel and more renewable energy.
If in the past you were able to get results for your location it's possible the CARMA web service was temporarily unavailable.
I hope this helps explain it. Let us know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
Marjorie Stein
QA Analyst
