Hi, I am working with Insight Carbon. In this regard I would like to know if the constructions seen in the Embodied Carbon (Base Model) section of Insight Carbon Analysis are the schematic structures defined in the energy settings in Revit. I find that the doors and windows pass according to their schematic configuration, but the walls in my Revit model, which have three layers, appear to have more layers in EC section. It indicates that it is a GBS configuration and does not match the schematic configuration in Revit. The construction of the slab also indicates that it is from CIBSE
Also, I would like to know if the energy settings in Revit (where you can set thermal properties of materials: conceptual and schematic types and detail elements) have any precedent for the constructions in EC or where these constructions seen in the EC section of Insight come from.
I'd like to know if all the energy settings in Revit affect the simulation done in Insight (e.g., the building type) or only some of these settings. For example, if the type of mechanical equipment defined in Revit is the same as the one used in Insight? or Insight uses ideal loads.
Finally, I'd like to know if I can perform an analysis with masses instead of a building with components. I tried using a mass, but I got a message saying the energy analytical model couldn't be created.
I appreciate any help with this.
