Update failed
Update failed
Update failed
I was using Autodesk 3ds max 2020. After the 2020.3 update came, I made the update. However, the "exe" file has disappeared and I started the necessary start to design 3-4 "dll" contents, although I deleted it and reinstalled it and despite the current removal uninstall, this problem was not solved. help plss.
srinivasarao.potla
Hi@ c.yusuf_1994,
Thanks for your feedback.
Could you please explain a bit more about the issue.
i would like to more about the issue, could you please send me the log files?
Please find the attachment for log file instructions.
Srinivas.
